RFSiesta
Yes!
We did rework the mic pres on our Trident 80 to non-inverting configuration.
For this the resistor R101(22k) is connected to ground instead of the transformer secondary, the non-inverting input of IC13 is connected to secondary instead and terminated with 100k to ground. This increases (and stabilizes) input impedance, which is good - the original inverting stage decreases Z with increasing gain.
Changed ICs to opa134, compensated the second stage with 10pF between out and in- for stability.
Sounds LOTS better! Clean, brilliant, tight, still with a character we wanted to preserve.
What's strange to me is that gain at zero position increased to approximately +12dB instead of 0dB.
This can be a problem with some really loud signals like kick drum or trumpet...
I now try to find a way to get the correct 0dB gain at position zero, if possible without affecting maximum gain.
I calculated (and tried) with changing R101 and R100(normally 22k), but didn't find a solution yet.
Any ideas?
EDIT: Attachment now works. Was a javascript issue...
Any ideas?
