Brian Roth
First of all, I dunno if this is the correct section here for this question....if not, I ask for the Moderators to move this to the appropriate section!
I am working with a friend/client who recently acquired an 80B desk in great condition, but is located approx. 250 miles away. I recently visited him as he was beginning to set up his new studio, and I brought back a nicely made set of snake cables which had been properly made for his MCI JH-24, but needed the other ends re-terminated into 30-pin Tuchels for the Trident.
As I "neared the finish line", I began to question the info published in the Trident docs.
Trident used three male and three female Tuchels "on the belly of the beast" for the ins/outs into the multitrack....one gender "per direction".
The docs are ambiguous. The pages in the manual for each set of Tuchels are for "multitrack inputs" and "multitrack outputs". Is this From The Desk's Point of View...or from the recorder's point of view?
Some Tuchel wiring pages in the manual are NOT ambiguous. Examples....mic inputs and control room/studio amp feeds. In those cases, the descriptions ARE from the "desk's point of view" as opposed to the external equipment.
I thought "well, look at the gender of the Tuchel connectors". No dice...mic inputs into the desk and monitor outputs from the desk all use a female Tuchel connector on the wiring harness.
Google didn't give much relief, although I found a few hints that the Trident docs were "from the viewpoint of the recorder". A few other items on my 80B paper copy (and an 80C PDF) also hint in that direction. Egads....
If I was at my friend's new studio build-out, I'd know the answer in a few minutes! He's a great guy, but a songwriter and producer...not a tech...so I won't ask him to poke around on the Belly of the Beast with non-existent test gear...LOL!
Thanks for any assistance, amigos. I don't want to solder the wrong genders onto the snakes!
Bri
PS...I should start a new thread on wire harness documentation/labeling, since I've NOT had these sorts of questions in my own designs for a few decades.....but then again, nowadays folks just start slinging solder with no sort of plan...LOL!
Bri
