ChrioN said:Falstad circuit simulator!
Its a single triode, and that one is a standard amplifier. Try a white cathode follower or something for (close to) unity gain.
This is the gain control stage of the compressor. The cathodes are probably connected to ground (not visible in the image), the center tap is fed with the control voltage (which also works as bias).skal1 said:so what topology would call this, it is the front end of 430c compressor.
