kepeb
did he? (EDIT: the OP 'decided') ah well, we weren't really helping after your (EDIT
RR) reply anyway, just arguing
cheers cc for clearing that up, i was feeling a little unwelcomed, thought i'd really hit a nerve, that wasnt my intention.
anyway, not sure if he sorted it (the OP)but he did mention it was for use on a single pedal, and i have to agree i would use the AMZ in single boss pedals without doubt. thats a good solution and alternative to an ugly carling sticking out of a DD6. and i dont doubt its MANY uses of course.
if he can somehow get the AMZ board from the US.. or reproduce the design for his single pedal where he is (third world?) then awesome.
apologies for off topic.
cc, please dont be offended, i am only talking.. Re: your pedals, i was referring to all the ground loops and trouble i have had eliminating DC noise introduced through PSU's and radio interference when using complex (or even simple) loops.
there were several sources of noise which override any fear of 'tonesucking' or true bypass concerns.
the first is with ground loops in a simple chain, i.e. stereo pedal has two 'outs', into two 'ins' of second stereo pedal being the simplest. in my experience even this can introduce radio interference. the there are extensions of this like signal splitters or a-b boxes with shared grounds, the loop becomes huge when you use two amps for your stereo signal and it is completed via the earth connection of the two amps!
very noisy. much worse than the damage say a 'Whammy IV' could introduce to your tone. and they are notorious.
secondly, you have noise introduced through your DC ground, which is often also shared. there are two more possibilities for noise here. the first being poor regulation of the DC initially, introducing hum etc. which is amplified particularly in high gain pedals. and the second being noise introduced to your DC supply by a pedal (eg. behringer or Line 6 modular range, i forget their names) although this is kept isolated within the pedal itself if they have a seperate psu, the DC noise on the common goes straight to any other pedal sharing the power and comes out the speakers.
this kind of noise can rarely be eliminated by seperatley regulated supplies as they still share a ground, although i think what you have is a voodoo2+ on the left?
i think this one has a separate winding for each isolated out??? this will stop that particular kind of noise coming back in.
that brings us to the ac adapters and transformers. in my experience you get more noise introduced through ac adapters which use transformers close by, than through any 'non' true bypassed pedals. I had to pay particular attention to how close they were, what's between them and even what angle they were at. plonking a pedal on top of your ac is probably not the best way to go if your worried about noise. especially ones with plastic shells like mine were back then.
personally i think true bypass has its place. its great for taking your wah out from before your fuzz face, as the proper FF relies on the changes of your guitar pickups impedance for its sound. but after the last of your first section (gain,dist,OD etc.) i see little benefit to true bypass and i certainly make sure there is a buffer before the end of the pedal board because you then gotta trail that signal all the way back to your amp!
but theres more to it than that of course, not saying i know it all. just saying
