Mbira
Hi all,
I'm sorry if this has been covered. I don't know what this device would be called, so I'm not sure what I'd search for! What I want to build would have balanced input that goes directly to a balanced output and also splits to unbalanced output. I have seen the jensen papers on using a traffo. The thing is I would like this to be cheap, easy, and generally transparent (no iron color). It'd be nice to be passive, but is that possible? No attenuation is needed other than the +4 to -10 step-down. I need this to be able to hook into two seperate systems-one balanced and one unbalanced obviously. Both outputs would be plugged in all the time, but only one system would be on at once.
Any ideas?
:guinness:
Joel
Any ideas?
:guinness:
Joel
