I’m ready to post some more specific information here, with one key question below. This is all a learning experience. This is for fun, but I’m being careful. I am aware I’m creating fire hazards for the time being.
I’ve finished re-housing / re-building from scratch a 1950’s Hi-Fi amp. It was a receiver unit that has a radio. I was interested in repurposing the amplifier / audio section as a guitar amplifier, putting that in a new enclosure situation, then leaving the radio section in the old chassis to utilize that separately some time in the future. So that’s what i did, but i also divided the power section from the audio section. So i have two small units, power, and audio. The radio stuff is still sitting in it’s old chassis, unused for now.
I followed the grounding advice given here in this thread, along with the filter/0V distribution described in the valvewizard article on grounding, implementing a heavy gauge bus rail for 0V. Everything seems to be working great. All noise is FAR far quieter, which is very exciting and a nice success.
The obvious complication when deleting a whole radio section of this unit is that I’m now missing that whole load of a bunch of tubes/circuits, so all B+ is going to be too high.
But before we get there… a side note… when deleting the radio segment, i pulled a 5.6K high wattage resistor, so i had that available. And it has a tap @ 100R, with 5.5K being second section, so a total of 5.6K.. This is indicated as R59 part A and B, in the posted schematic below.
As expected, when powering up my new system that did NOT have the radio 5.5k + circuit load on it, and with no mods to compensate for this, the main B+ voltage is of course too high. It settled around 410 DC where as it should settle at 360 DC. So I figured, let’s have fun and try hooking up that high wattage 5.5K resistor section loading B+ to 0V just to see what happens. I know it’ll get hot as hell and i might even damage things or start a fire, but a short trial might teach me something. Worst case i destroy my amp and use my fire extinguisher haha. This power resistor is pretty large, at 3 inches long and 5/8” thick, so maybe it can handle some short term heavier wattage.
So i added the two mods drawn in light blue below. The other mod is a 7W 125R resistor I happened to have on hand. Figured maybe it would help lower voltage, assuming I’d be too high still. And on first power up, I ended up with an absolutely spot on 360 DC B+ rail. Bizarre. This is pure luck of course, since this in no way resembles the whole radio circuit.
But yeah, the 5.5K to 0V gets hot. You wouldn’t want to touch it for more than a second, or even less. Also, the neighboring components are now quite toasty. The added 125R resistor is hot too, but not as much.
This is not a safe or permanent setup. But man, the sound of the amp is exactly as original, sounding incredible but now also very quiet, so i know the dummy load mods are functional to whatever degree.
What can i take from this? Can i simply but a much higher wattage 5.5K resistor as this dummy load and call it a day? 100W perhaps? Maybe the heat will be handled by the resistor and it won’t fry neighboring components? According to my understanding, my setup sends nearly 25W through this resistor, as well as around 65mA. That’s a lot of lost energy. However, i suppose that if I’m nailing the 360V DC with this, it perhaps means that the original radio circuit is burning exactly that same amount of juice? Obviously the power transformer already was designed to provide DC current to a whole host of more tubes, so maybe it has around that much to spare anyways, and would be the reason the voltage is now back to spec.
Below is a clearer sketch of the original power circuit, and the two mods in light blue that give a 360V DC B+ result. The original schematic is weird to trace, so this is much better.
In a dreamy ideal world, i would have a toggle switch that allowed me to either engage this dummy load, or engage a connector that send this original B+ rail through 5.5K to the separate radio unit. Then I can power up the radio with this same power supply and audio amp. The radio tubes and indicator lights were all on their own 6.3VAC, and right now i just have one indicator lamp hooked up. The voltage is probably too high but i haven’t checked yet. I could install a drop down high wattage resistor there too.
One great perk of this setup is that the high voltage gets drained almost immediately after power down. Maybe a handful of seconds. That’s really handy!
![IMG_0744.jpeg IMG_0744.jpeg](https://cdn.imagearchive.com/groupdiy/data/attachments/96/96380-816d8c15e287e91df3bdfc506433aa57.jpg)
