Hi Guys,
Well a friend of me called me today to tell me that he had some kind of weird issue with his Guitar amp, so i went to just have a visual look and know about what he did before that, and from visual everything seem to be fine inside the amp no burned components, all tube glowing etc...
I'm not a pro in Tube amp repairs and all, and a little knowledge from you guys would be great, here are the symptoms and what he did before they appeared:
First he builded himself a cabinet to fit two 12" Eminence speakers, for now nothing fancy.
Second he hooked up + beeing the tip of the jack, and - beeing the ring of it, everything ok.
Third after a quick test everything is ok, sounds nice, but he had some ECC83 / 12AX7 tubes from Sovtek and Tungsol to try out.
So he openend the amp and tried some different combinations of tubes in the V1/V2/V3 Section of it, wich is i believe Clean/Distortion/Phase or something like that? Sorry for my noobiness .
But after some try outs, well no more sound, very weird, he told me that he swapped them while amp was off of course, and waited a minute before replacing, and a minute before lighting up again, and that for about 5 or 6 different combinations for some minutes before nothing, when doing the last combination and lighting up the amp again, and then nothing, all the amp seem to be feeded, LED lighting up with footswitch, all Tubes glowing etc....
Anybody Knows what could be the issue ???, i mean normally changing tubes with same ref tubes is no prob right?, or where can i look at and check with DMM, to spot the prob.
I don't have huge experience in troubleshooting Tube Amp, i know that i have to be carefull while working on them that i know, safety first .
Anyway Thanks for your help.
