Winston OBoogie
The 'S' version of the V76, somewhat surprisingly called.. the V76S
had the ability to send the signal from the 1st double EF804S valve input stage out to a compressor, and then bring it back into the EF804S/E83F output stage.
I've never seen the schematic for the external compressor part and relatively few were ever made - it was an EMI Cologne/Carl Lindstrom, Peter Burkowitz designed affair.
I do know that the compressor was a stripped down version of the U73.
I'd bet it used 2 of the 188 1:1 transformers for in/out of the comp section, and another 188 1:1 as output of the side chain amp.
And with possibly an additional cathode follower to drive that input T188 transformer... ? I don't really see how the output impedance as shown on the V76S 'send' line could drive the 188 transformer without a buffer but? Maybe that little cap across the 80K resistor compensated for a high end loss from the transformer but...
Anyway, it can be done.
But the U73 is feedforward and needs careful setting up etc. to get it to rock out properly so, be warned.![Wink ;) ;)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
