MatthewMachinist
Member
- Joined
- Aug 19, 2020
- Messages
- 10
I have a noob question... I am going to build a Reddi clone and I am almost ready to start building. However I am really uncertain regarding the best way to solder all the components together. I have done some research and found an excellent article by R G Keen http://www.geofex.com/article_folders/pt-to-pt/pt-to-pt.htm
But I am still unsure what would be the best method for a DI box, I am thinking of using stripboard for mounting the rectification circuit and smoothing capacitors.
If I solder the B9A tube socket to a PCB board will that work... do I need to order a special type to make it work Universal prototyping PCB for tube amplifiers Type I
Any help would be appreciated, I have a background making DIY effects pedals but I have always used a supplied pcb with a kit, this is my first time going full DIY.
Matt
Matt
