Some more noodlin' ....
Looking more closely at the transconductance curves for various tubes, I'm getting a feel for what I'm after.
ie. a shallow transconductance curve where it can spend 'most of the time' (around 5mA), increasing to max -1V at some (high) current in 'deep limiting' ie. 'very occasionally' and way down to -25V at the min usable current (no nothing) 'very occasionally'.
Thats a range around 0 .. 25V of CV to the grids.
Its clear that I will benefit from :
a) a higher pentode screen voltage ie. closer to 250V than to 150V
b) a sizable screen stopper resistor to really flatten out the gm 'dive' over the decade (or two!)
That will allow for a decent 'idle' current at signficant grid voltage whilst allowing the CV some 'room to move'
Right now its a 6BJ6 which holds up well even when discounting the appeal of it's crazy low heater current. ;D
It has a strong max gm (4500 ish), a decent max current approaching 15mA pretty easily and can be made to flatten out pretty well to provide a broad grid range (to around -20V meaningfully) before current gets too low.
If one is able to afford a more common 300mA at 6.3V heater, then the usual candidates are usable too.
This time, it looks like a russian candidate leaps out. Off to ebay (again)
NOW,
in 'my' gain-cell, there is some plate loading of the push-pull cathode followers - this is to allow a balanced feed with a little voltage gain to the sidechain.
HOWever,
I am first going to go *without* plate loads - pure CF
That means sourcing the sidechain input signal further downstream, which in this case, is all unbalanced.
SO, either a phase splitter tube stage OR an additional (highish Z input at least) transformer.
I like the simpler, 'purer' version ( for want of a better term) with no plate loads.
Even choke loading might be possible, but I'm leery of unshielded anything, ever, anymore
Even despite external psu!
The action of the varying current causes, of course, the plate voltage to vary due to a plate load resistor. This can work against the compression action ie. varying the gm, in a pentode mode setup.
ie. it is a useful simplification to have a constant plate voltage, at least at first until I get a feel of things
SO - looks like the vari-gm gain cell is going to be pure CFs
more likely with the 6k13p remote pentode or it's slightly less power rated (2.5W) us type, 6eh7. I have a few nice nos ge ones to give a workout in this here build.
As always, it can look rosy on paper but turn out poorly - fortunately I haven't experienced that, so onwards and upwards here.
NOW to decide - an additional pair of tubes or transformers ! Either way, its a win.
NOW,
HOWever,
