Tube Mic Preamp Power Transformer and Phantom Power
benlindell
NYC
Quick and simple question, what are you guys using for tube mic pre power transformers with regards to phantom power?
Alternatively, there are a couple of valve PSU transformers available with an extra 24v winding, such as these:
http://don-audio.com/toroidal-toroid-trafo-transformers-power-transformers-audio-transformer-Audio-Toroidal-Transformer-pri-230V-sec-335V-01A-24V-05A-12V-2A-1-12v-24v-335v
http://www.musikding.de/product_info.php/info/p1361_Toroidal-transformer-230V----250V--9V--24V.html
As long as the 24v winding can supply enough current, you could use a voltage doubler to get 48v. I've got one of those Musikding trafos (which actually says 24v at 0.5A on the sticker). I'm planning to give that one a bash as an all-in-one solution for a valve mic pre...
Matthew
hammond will wind you a  pwr trans with a 48 volt tap,
i even got a print and a part number, forgot the price, it does not have to be a group buy, but it will be a bit more than there usual  120>240-12.6 ct.
then, if everybody started buying them, they would put it i the catalog.
fwiw you can get a linear PSU that has 115 Ac on the input and 48VDC @ 1 amp on the output from mouser for like 30 dollars. Might just be cheaper to add that into the whole chain....
my manley 16 channel mixer works in a similar fashion where all the voltages needed are on their own PSU board...
Excuse me if this thread is out of date but this one is very nice…
https://www.don-audio.com/Audio-Toroidal-Transformer-Pri-2x115v-Sec-250V-48V-12V
MVH
/John
