I agree but also, If the music is cooking it will transcend the medium. Dean Benedetti's wire recordings of Charlie Parker's live solos for instance.And:
Reference Recordings | Since 1976, The Best Seat in the House
A lot of Music on Decca and sublabels is rather good, Decca/l'Oiseau-Lyre is excellent.
I have always argued that a great system can even make very poor recordings of great music involving and listenable. I have a test track for this.
The Chicago Transit Authority live playing "25 or 6 to 4". Terrible recording (maybe straight from the line out of the live mixer), but the band is totally on fire. If you can get past the recording quality.
A good system will do that. Get you to the music, past the recording.
Most rooms at hifi shows absolutely refused to play this (when I was still reporting hifi shows) and cut it after a few bars. In most cases I didn't mind either.
Thor
Strickland uses the mosfets as amplifiers. Little wiggle in = bigger wiggle out (+14db). Moscode and Hafler use mosfets as followers - big wiggle in = slightly smaller (-1db) wiggle out. Totally different. Transnova is like a vacuum tube PP output, w/out the xfmer.Tell that to Mr Moscode...
That is meaningless.
Where you place a coupling cap has no real impact, as long as you size it correctly.
Lateral FET's are actually very begnign loads, especially in grounded source mode.
You only need +/- 8V drive and the node to be driven is mainly capacitive.
Obviously not. Clearly Stereophile Class A rated products and EISA awards plus a raft of lesser stuff don't count.
Yes, of course.
Thor
Never heard of “runaway” tubes ?Where you place a coupling cap has no real impact, as long as you size it correctly.
This is from the Zotl patent. It functions as an active DC resistance transformer allowing a tube with limited current capability to control a much larger amount of current. It is not Class D topology. There is no comparator to turn the audio into pulse width modulation. The clock F is fixed as is the pulse width. When the tube conducts the whole block it's attached to conducts through its current amplification factor. The actual speaker current goes through converter which is controlled by the loading of the tube. If the tube shorts the converter carries its max current, if the tube is open or off then the converter allows no current to flow through it.
This second circuit is a class D amplifier with a comparator and does not use the tube in the circuit that controls the speaker. All it can do is amplify what ever is fed to it and output that into the + input of the comparator. So if you have a really linear (perfect) tube circuit the output will amplify that. If the tube is non linear and distorts on its own the amp will output that. The load does not affect the tube character like the ZotlNow, how does this differ materially from this (conceptually - not showing tube biasing etc., coupling devices not shown, not verified for specific polarity etc.):
And can my second example be made to materially match the transfer function of the first?
And can my example be made to have < -100dB switching frequency (I like to use the term "Carrier") on the output? Presume ~ 1.5MHz switching frequency.
Thor
RE thermal runaway - a mosfet will do that if it is not well heatsinked.Never heard of “runaway” tubes ?
Mosfets may not suffer from that but still present a capacitive load depending on usage as mentioned.
If you want a fast amp you make sure that everything in the amp is able to keep up or better : exceed !
Best regards,
Frank
This is the best explenation i have yet encountered !!!!This is from the Zotl patent. It functions as an active DC resistance transformer allowing a tube with limited current capability to control a much larger amount of current. It is not Class D topology. There is no comparator to turn the audio into pulse width modulation. The clock F is fixed as is the pulse width. When the tube conducts the whole block it's attached to conducts through its current amplification factor. The actual speaker current goes through converter which is controlled by the loading of the tube. If the tube shorts the converter carries its max current, if the tube is open or off then the converter allows no current to flow through it.
The point is to reflect the transfer function of the power tube thru the converter to the speaker and reflect the load of the speaker thru the converter to the tube. The same as an iron core transformer but without the iron core limitations of parasitic capacitance, phase shift, core saturation, inductance and all the other xfmer downsides.
According to the reviews it does so quite well. However it is not a pulse width modulator class D amp.
I thank you kindly. I hope Thor gets it. Really a brilliant design by Dave amplifying in the ether (meaning RF). Thanks for bringing this to my attention.This is the best explenation i have yet encountered !!!!
Finally !!
Thank you. I can't really measure below 10 hz on the bench. I have to look at phase shift to see the effects.Impressive numbers !
Effordless is key of any amplifier design. The impression of unlimited power (within it’s limits)
No. The output stage is cap coupled to the driver K follower. It has its own floating bias supply and servo all on the output board. It all runs off the hi power windings on the power xfmer. The output and input of the tube circuit is fully muted during warm up and the mute relay to the output stage speeds the servo up during warm up. All muting is a short to ground so no audio goes thru relay contacts on play.Like this ?
The is second circuit is a class D amplifier with a comparator and does not use the tube in the circuit that controls the speaker.
But of course it does.The load does not affect the tube character like the Zotl
Thor: No PWM, agreed. But still switching.However it is not a pulse width modulator class D amp.
This question referred to a tube stage of any kind connected to the input of a class D amp, not the Zotl.Are you sure that the tube does not drive the load?
