tablebeast
I have been modding Bogen PA amps into guitar amps for years. One of the first thing I do is rip out this "remote control" or "precedence" circuit. It has a lot of stuff going on that I don't need if I'm just doing a plexi type circuit or whatever. I like to gut and rebuild from scratch anyway.
But now I am curious about this type of remote control for channel switching/fading. Curious enough that I bought a Bogen SR-2 to check out what was inside it because I couldn't find a schem for it or the SR-4 units online. Unfortunately the SR-2 I got was heavily modified so I don't know what is stock and what is mod.
Anyone have any clue what is going on inside the remote circuits in these old PA tube amps? Is it just a pot and a resistor? And what is it actually doing? Lowering the voltage would seem to lower headroom as well. Could be interesting in a guitar preamp circuit I'm thinking, like a voltage starving effect. My best guess is that it uses a pot with a resistor in series across the B+ voltage rail to ground. The extra .22uf filter cap between the B+ where the control circuit wires up and the next two plate resistors in the RCR must be there to smooth out a pop if a shorting switch was used with the remote. Adjusting it looks like it raises and lowers the voltage, which in turn should lower and raise the gain accordingly, but in a different way than adjusting the volume control. I don't have one of those amps on hand at the moment, so I am just guessing here.
I know it should be very, very simple. But Bogen has a few different things that can be used as a remote besides the basic 2 (SR-2) and 4 channel (SR-4) control units. Stuff like the RVC-2A and the LVP-1 seem like they are some kind of different circuit entirely. I'm really just trying to start a discussion about this kind of control circuit and how it can be deployed in new and interesting ways.
