Nele said:aha.. this is a newer one with 33V for the heaters.
I've replaced the heater psu-cap and things haven't improved
well, I replaced the cap because there was ripple on the 33V/48V psu, just as you suggested...? we're talking $ 0,25 here so always worth a try . or is there a way to check which capacitor in the psu might be faulty?pucho812 said:If there is ripple then there could be a bad electrolytic cap or several bad electrolytic caps in the PSU
I've always found testing caps with a multimeter a bit unreliable because the testconditions are not the same as the in circuit-operation. I recently replaced a fairly new multi-cap in a Leslie 147 for instance which measured ok but turned out to be fried.pucho812 said:checking for caps, use a multimeter and make sure you de-solder one side of the cap to see if it is working much like checking resistors.
both..pucho812 said:which side had the ripple? 33V or 48V? did you go over the solder joints?
yes, but as I had to disassemble the unit to do so I haven't been able to check if it had any effect yet. stay tunedpucho812 said:did you go over the solder joints?
