SSLtech
Referring to this schematic here:
http://www.schematicheaven.com/fenderamps/twin_reverb_sf_100_schem.pdf
There's two 'MVS' switch poles, each with a number 5 in a triangle... one JUST above V4B, the other just above the reverb tank dotted rectangle.
So on my amp, this doesn't do anything. -I wouldn't normally worry, but I'm about to sell it, and the buyer wants EVERYTHING to work. -Heck, I don't like the sound of what happens when you pull that switch... I don't really see how anybody COULD like the sound it makes... but do I agree with the buyer that if I want a fair price, the unit really ought to be in full, correct working order... after all, it's how I would like to be handled by a seller.
Replacement 2-pole pull switch log potentiometers with splined shafts ares apparently made of 'unobtanium', and -measuring the circuit, I found that the upper pole in the drawing (the one which shorts out the 1MΩ resistor) is operating... but no noticeable change in gain, and no 'distortion' sound. the lower-drawn pole doesn't seem to short in either position.
So I tried swapping the poles, thinking that the OTHER pole did more...
Still no change in gain, no 'distortion' sound.
I'm afraid that I don't see what these are supposed to do... does the circuit require BOTH poles to open/close simultaneously to operate properly?
Everything else works correctly; Reverb, tremolo, both foot-switches, both 'bright' tone-switches, tone stacks, and the amp sounds big and strong... -bigger and stronger in fact than the brand new "1965 reissue" twin reverb which I just put next to it.
Can anyone explain the circuit to me, or give me some pointers? -If I can't get a 2-pole-pull-switch-splined-shaft-log-pot of the correct value, should I maybe use a 6VAC 2-pole relay, powered through the remaining working pole from the heater supply? -Would that work? I really DON'T want to start making this unit excessively 'inauthentic', though.
The wise counsel of experienced tube guitar amp gurus is appreciated!
Keith
Keith
