@kingkorg
"Don't mean to question your findings, but IMHO, and experience with measurements, there is no way this kind of result can happen where off axis and on axis can diverge that much. Allign off axis but not on axis? There must be something wrong. I'm not aware how physics would allow this."
PLS interpret the diagrams correctly. There is no off axis response BUT the relationship between 90° frequency response and 0° frequency response. Therefore it is named polar response PR.
"Not saying either Neumann is flawless, but if on axis diverge this much, off axis has to diverge too."
Yes of course, it does. But polar response is what you have to discuss (again correct interpretation of my measurement results helps)
"I think i know what happened. You need to take a measurement of your reference mic at 0°."
Thanks for the hint
I ALWAYS publish the FR graphs after dividing the DUT measurement by the REF measurement !
"Alling spl of all the measurements at 1Khz."
Doesnt make sense because FR @ 90° / FR @ 0° tells the whole story about mic directivity type (super- hyper- cardioid).
"You also have to work on the space you are measuring in, or do it outdoors."
Why that? Comparing all measurement results is independent on room influences because the measurement conditions were the same for all DUTs.
"This much smoothing isn't the way to go. Especially if you are measuring off axis."
The same as before: measurement conditions are the same for all DUTs. Therefore smoothing doesnt change anything.
But you didnt get my point: frequency response does NOT tell you the whole story regarding off axis response. Matched frequency responses are no guaranty for matched directivity. Same applies vice versa as proved here. Matched directivity can lead to significant deviations in frequency response.
Therefore i repeat my requirement for matched mic pairs:
1. matched directivity rules,
2. frequency response can be equalised (of course only in the DAW),
3. sensitivity can be corrected easily by gain knobs or in the DAW.
By the way: I am wondering why your SB Acoustics drivers do not perform well. Try to measure frequency responses at 10 cm, 31,6 cm and 100 cm distance and compare them to each other. They should have 10 dB distance from each other and match to 2 dB over frequency...
