Typical Audio Interface Balanced Output > TS (unbalanced) 1/4" Jack (OUT). Safe???
777funk
This would of course short circuit the Negative side of the balanced signal to ground.
I'd think most interfaces would be designed to tolerate this. No?
I ask because I have an M-Audio Profire 610 that I've connected this way and after a few months of this, that output is having some issues. It's both channels of the stereo out that are having issues as well as the headphones out for channels 1+2 out. I'd think the actual outputs would have different opamps than the headphones, which makes me think it's further upstream and not the output opamps that have been damaged. Of course it's hard to know. But back to the question, wouldn't most manufacturers design the opamp out circuits to handle shorting half of the balanced signal out when someone (perhaps technically incorrectly) uses a regular 1/4" jack?
There isn't really "a" typical balanced output circuit, there are three.
For TRS outputs typically yes. For XLR practice varies quite a bit.
For best results you can modify your connections based on type of output circuit, but unfortunately the ProFire 610 user manual does not seem to give any clues as to what type of output circuit it uses.
The line outs have a series electrolytic capacitor and a mute transistor on both hot and colds.
The headphone outs don't have inline capacitors, just the mute transistors.
Normally these sort of problems are down to the capacitors exceeding their sell by date, but as the headphone also seem to be affected which doesn't have them, you would have to suspect the mute transistors, or the mute circuit that is driving them.
As all these are affected I would be looking at the mute circuit, which is not generically uncommon.
Op-amps don't usually get damaged, they either work or they don't, so this is not likely.
Is there any possibility that the second topology I drew here is used? In that case changes to the line output could affect the headphone out.
I don't know how likely that is, my guess would be not terribly high.
Line outputs and headphone outputs have dedicated op amps.
This is normal, that is not.
I don't see any value in guessing here.
No they are not.
They are simply saying they have been connecting a balanced output via an unbalanced jack, thus shorting one leg and questioning whether this might have damaged anything.
They then have postulated on here the fault they are now having is due to this fact.
Now I am saying the fault they have is nothing whatsoever to do with using a mono jack in a balanced output, but is in fact due to a fault in the Mute circuit.
@777funk - can you describe what 'the problem' here is? Do you get any audio? Audio plus noise or distortion? Nothing at all? Is it intermittent? Is it the same for left and right channels? Tell us everything you know.
The audio volume is in and out like a dirty pot. And it's distorted and clear also. On both L + R channels. Interestingly, channels 3 and 4 are fine.
Thanks NoisyIndividual. I will look into the mute ckt.
