Well done. Very neat build. Is it OK if I pass the pics to Pierre who keeps an independent gallery of builds based on my designs?
Hi Ian,
so in practice, just feed a hotter signal into the box for more colour.
I am not sure which page 13 you are referring to. Can you please clarify?The attenuator; I assume that would be a dual gang 1K LOG pot like depicted on page 13, but instead of using it as a pad on the input transformer, it would be connected in the same way on the output transformer? The schematic on page 13 also shows resistor R3 of 68 Ohm, would an additional resistor also be necessary in this application? If so, what value would be best?
Cheers, Alex
Thank you for the explanation Ian, and apologies; I could have been clearer with my question.Yes, that is right
Edit: I just realised which page 13 you are referring to - the build instructions. Page 13 show a variable mic input pad whereas what you need is a variable output pad. Two versions of a suitable circuit are shown on page 23 but these days I just use a straightforward 1K LOG pot wired across the output transformer secondary.
That is exactly what it is there for.Thank you for the explanation Ian, and apologies; I could have been clearer with my question.
The output pad on page 23 of the build manual looks simple enough, it's just a dual gang LOG pot. Since this pot attenuates the balanced signal I assume this one comes after the output transformer, thus giving the option of running the entire unit hotter including both transformers? If so, it keeps getting better and better.
I don't sell many PCBs these days so unfortunately I rarely update that section of the web page. As you know I have open sourced a lot of them. I am pretty sure I have a few classic solo PCBs in stock.I haven't been able to find the PCB files for the Classic Solo Lo Hum on your site, and the PCB shows on stock even though the page says that the table was last updates in may 2021. Does this mean I can buy one from you? If so I will send you an email, as instructed on the page.
Cheers, Alex
I saw you open sourced many projects, much respect for that! I guess the Classic Solo is not one of them (yet). Nevertheless I'd love to support your work by buying a PCB from you. I'll send you an email to work out the details.I don't sell many PCBs these days so unfortunately I rarely update that section of the web page. As you know I have open sourced a lot of them. I am pretty sure I have a few classic solo PCBs in stock.
