Original U67 has a pertinax insulation boards between PCB and the transformer core. Yes, original PCB pins are close to the transformer and since my Bv.12 is a direct replacement I produce it with the leads lenght stated in the Bv.12 winding data. Sorry because you had to improvise.- Getting Moby's transformer through the rectangular hole was a little tricky because of the wire leads. I pushed one side in and then worked each wire though. The wires were close to too short and I had to extend one. If the wire leads were slightly longer it would fit better. I think a 'real' u67 has the connections lower, but I didn't want them under the metal core so I put them up higher.
It's to compensate for the capsule, I think. Those capsules changed a lot in the early days
Ahh, interesting. So the wire leads and bobbin don't sit through the board. That would make it simpler.Original U67 has a pertinax insulation boards between PCB and the transformer core. Yes, original PCB pins are close to the transformer and since my Bv.12 is a direct replacement I produce it with the leads lenght stated in the Bv.12 winding data. Sorry because you had to improvise.
I'd be interested in some boards as wellI designed and got the first samples this week. No major mechanical problems yet.
I think you did it mechanically the same way as the original but you excluded the pads for the TX leads. Transformer is "sitting" on the bottom PCB but leads are connected on the bottom side. Generally speaking those pads are right under the core but as I mentioned, core is insulated with small pertinax boards (30x10mm with hole for screw). Please take a look at the photo and see the pads position. Maybe you can revise the PCB to come closer to the original.My understanding is the capsule was designed with a high frequency boost that was attenuated by the amplifier to have lower noise. Overall flat frequency response. The manual excerpt I posted was 1963 and the later spec sheet was 1981.
Very reasonable that there would be some capsule variation. I'm trying some differences in C17 and will post the results later.
My design is inspired by but not exact copy. Anyway it works.
And I meant no criticism about your transformer, it's performance is fantastic. Just a little improvisation to fit it into my board design.
looks great!View attachment 119068View attachment 119069
View attachment 119070View attachment 119071
conversion of the Chinese copy of U87Ai into "U67"
You're not allowed to link to that directly here IIRC, only discussionThnx The microphone cost the owner about $630, free shipping to Moscow.
I suspect that may have been a warning rather than a promotion.You're not allowed to link to that directly here IIRC, only discussionThnx The microphone cost the owner about $630, free shipping to Moscow.
the owner specifically bought this fake u87 for conversion into a u67, everything was thought outI suspect that may have been a warning rather than a promotion.
It looks like the owner may have originally purchased a fake rather than a clone
Sorry, totaly misread that. That's not gonna be a cheap project thenthe owner specifically bought this fake u87 for conversion into a u67, everything was thought out
