And in the end all the critical connections end up connected to the pcb through the switch terminals? Or am i missing something?The teflon pins are expensive unfortunately. Some think you can skip this since modern PCBs have very high impedance.
Or if you want to cut costs, I'd suggest buying teflon tubing and making them yourself. Use resistor cutoffs with short pieces of teflon tubing.
But it's DIY so anyone can do whatever they want.
I have, possibly a rookie question... I'm looking at the 67 builds and they're asking for 400meg resistors, I've gotten everything else I need but am i dumb here? I've done a couple other builds but cant seem to find these values...
ok, I've managed to find everything else. Just not that. and I know these mics were designed with 5 or 10% tolerance to it shouldnt be an issue. just factory lead times for shipping things can be a problem sometimes lolJust about anything goes - your best bet is probably 470meg (a standard E6 value), if 390meg or 430meg can't be found.
https://www.mouser.fi/ProductDetail/TE-Connectivity-Holsworthy/RGP0207CHJ470M?qs=sGAEpiMZZMtlubZbdhIBIFho3SHfDXStbowBqeLHeqs=
Same goes for the "60meg" ones - 47meg / 56meg / 62meg / 68meg are just as good, but are standard values that CAN be found nowadays.
hahaha I'm the same. I started just picking up random carbon comp resistors and misc things when im working on some builds. I picked up the 470megs wihch should give me a solid device still. I made a DI a few months back with an old Jensen output transformer from some tube console and used such bizarre values that on paper it shouldn't work but gives me such a nice brown vintage tone to it... I may actually change them up for the hell of it.If/when I’m feeling particularly compulsive about trying to get a weird value, I usually dig into my lower tolerance carbon film resistors hoping to find enough deviation for a close/exact match.
Although, I must admit, I’m often ‘disappointed’ to find them much closer to spec than I’d hoped.
ooh sorry, the 400meg. but yea i only try different things on passive circuits. like passive DI boxes etc. I try and stick to general rules of circuitry when working on active gear.Just not which "that"? Some might say i'm great or whatever, but i definitely can't read minds
Even before worrying about component tolerances, it's useful to be aware of the ROLE the respective components play in the circuit. In some cases, things work 95% as well, across several orders of magnitude (10k vs 100k for a resistor, or whatever).
making sure tubes are properly biased, op amps have correct circuitry, stuff like this. proper calculations for what kind of bass roll off i want or what inductance I need.And those are...?
