U87 (Revision A) in BM800 microphone donor body
Hi @mihi_fuchs
Yes, I will do.
I have checked the U87 Building Guide and for my understanding, to refine RV10 for the best sweet spot is to generate a tone via J4. How can I do that without special equipment?
If not, which cheapest kind of machine should I be looking for?
Or preferable a portable digital tone generator or portable digital oscilloscope will do the trick for this and bullet proof for future projects?
A low distortion sine wave generator. Maybe you can use your sound card for that too. I never tried. But you can give it a go. Just be careful and start very low in volume.
I used GND on Capsule/body which i took a cable from XLR pin1 and J9, is that correct?
that's perfectly fine. Values look good too.
Good idea, let's see if I can figure it out.
| QUESTIONS |
1.
I must give a lot of gain to have a reasonable level of sound, is this normal?
Nope, make sure you have the PAD jumper in the right position. Check with guide, there is a description for it.
Additionally make sure you have put the Transformer wires in the right connection holes. If you changed the direction of the transformer that can also result in low signals.
2. When I activate phantom power and start giving gain, I hear some crackling which goes away after a few seconds ON. Is this anything with the transformer? Does it need to break in on order to have normal results?
No, a crackling noise is fine or the moment switching it on. But not for too long. The capsule is fine, is it?
The transformer has little to do with the phantom. It is more the DCDC converter. Voltages around the Transistor on the DCDC board are stable, are they?
Always very helpful. Thank you so much @mihi_fuchs
Best Regards,
RB
Here you can find some good info about soldering
If i were in the US I'd try the Jli capsule you can find it here TSC-2
Never tried out for my build as I'm from Italy and shipping makes it inconvenient, but they're not so expensive so worth a try in my opinion if you are in the US.
About the cleaning process, I didn't wash the pcb as you see in the video you mentioned, I've just used some Isoprophyl alchool on a towel and a toothbrush, or cotton fioc for the HiZ junction, and the mic is incredibly silent.
One thing I receltly implemented are a pair of 22nF caps at the XLR, as I was having some RF noise.. now it works perfectly.
@antocu ,I'm kind of having the same problem with RF noise...which part specifically [on Mouser] did you use as 22nF caps specs for the XLR?
What kind of noise you're getting? I have built three of these, and two have sort of a hiss noise, more of a fizzy kind, not smooth, and kind of over the normal noise floor, but its only present with certain preamp combinations, and only noticeable at very high gain settings, otherwise not noticeable under normal circumstances. I think it might be RF interference too, since it was mentioned somewhere on this thread, mihi omitted some inductors that seem to act as RFI filters too. Boards are clean, and so is hiz section too, and mics sound wonderful. I'm going to give a try with the RFI OPA filter too, thanks for the tip....
I'm still working on them. I need to set the gain very high, and I have a bit too much floor noise, too. I will do what Mihi said and see how things work out. I'll keep you posted.
Hi, i think I had these caps K223K15X7RF5UL2
These are X7R caps, generally frowned upon when used in the audio signal path for the distortion they add and their microphonic behavior. Admittedly, I'm not sure whether that will be audible. For RF purposes, they are at least much better than film caps.
In many mic designs, you'll find these caps as RFI filter. The 22nF value originates from an era without cell phones and in many cases prove to be ineffective against cell phone interference, which is the most common source of RFI nowadays. Even when these caps are mounted on the XLR's. I've done RFI tests on various mics with various 22nF locations. It was a hit or miss whether it worked or not. And combined with the capacitive load of long XLR cables, it could also cause early top-end fall-off.
The KM84 has a similar RFI susceptibility. I was able to effectively suppress the cell phone RFI issue, but only by adding a SMT component RFI filter, combined with a XLR insert with short pin 1 to chassis connection (Being short is important here. Literally every mm of wire between RFI filter caps and chassis ground reduces the effectiveness. That's also the reason wired components are less effective than SMT parts.) It's the same XLR insert as used in the Takstar CM-63, which has very effective RFI suppression.
I've copied the RFI filter to a small PCB that should be mounted on the XLR insert. See attached picture. I've tested it in several LDCs and works quite effectively when tested with an RF jammer between 500MHz and 1.2GHz. Will make the board available through PCBway in due time.
See also here: Post in thread 'Is there a way to reduce cell phone interference in DIY KM-84?' https://groupdiy.com/threads/is-the...-interference-in-diy-km-84.86707/post-1160686
Jan
    1.1 MB
problem with RF noise...which part specifically ... did you use as 22nF caps specs for the XLR?
Serving Suggestion 28737 -- Do less to protect the microphone - and more to mitigate the source of RFI/EMI.
Rationale: I am a funny sort of guy. Rather than install capacitors on all my microphones, or have a studio/shack festooned with a gazillion clamp-on ferrite beads, etc., I identify, isolate, and mitigate the source of interference, instead.
Many amateur radio operators sustain RFI in the shack, and cover the problem with various tricks, especially clamping ferrite beads on every audio and RF patch cable. I believe these issues are best resolved with judicious routing of cables, cinching up loose connectors, and employing best installation and operating practice. I have a pile of audio gear stacked next to a 1500 watt RF deck with no issues. Moving cell phones away from sensitive equipment is nearly always sufficient mitigation. Except for ordering more beer and pizza, I cannot imagine why anyone would need a cell phone in a recording studio . . .
Just is just MY take ... I am not being critical, argumentative or judgmental - your mileage may vary! / J
yes they do. but you isolate them via the teflon part. the hole in the pcb fits the teflon ring leading to no contact to the pcb. top and bottom part are conducting, but no contact to the pcb is there as the teflon parts isolates.
Hmm. I’m not seeing a hole large enough on the PCB for the 11218 teflon to fit through. Is it supposed to be right where my pencil is pointing in this picture? Should I drill it out so the teflon will fit in there?
EDIT: I see in the build guide that it was drilled out. I just drilled it out and the turret fits fine now. :)
Yes. You have to drill it out. My apologies. On initial orders i did it before shipping. However now i do kot do it, so you have the option to go as you prefer.
Makes sense. That’d be good tidbit to add to your build guide, unless you already have and I’ve got an old version of it.
I just finished up my build (thanks @mihi_fuchs) and so far the mic is sounding great! Here's a little REW capture (totally non-scientific because I'm just placing it right in front of my monitor speakers and playing the test tone) comparing it with the DIY U87 I made with the Dany Bouchard PCB in an Aurycle A460. The Bouchard vintage U87's output is lower (as expected).
Just now I'm realizing that I don't have a shock mount that works with the HL-95 mic body. Doh!
DIY U87A (Fuchs PCB)
HL-95 Mic Body
Arienne Audio K87 Capsule (v1)
3U Audio GZT-87 Transformer
DIY U87 (Bouchard PCB)
Aurycle A460 Mic Body
JLI TSC-2 Capsule
AKG P420
Modded with 470pF added in parallel with the existing 220pF for a total of 690pF. I've gigged with this mic as our center mic in an acoustic bluegrass band and it is stellar).
Once I find a good shock mount (open to suggestions), I'm guessing this new DIY U87A (Fuchs) will be my go-to for gigs.
