It was one of the pair of R's that biases up the base of Q4. Both resistors should be equal and are, in the 1176, supposed to be 2.7 Meg each. The top resistor was indeed 2.7 Meg but the bottom one was 270K! I checked the proto units that were on a special engineering shelf and all the parts were the correct value. I then checked the units that were being built and coming off the production line. All of them had the wrong 270K resistor installed. I checked the B.O.M. and, sure enough, that part was shown as a 270K on the production document but was accurate (2.7M) in the proto docs. I notified my, then, boss about it and after a meeting with his superiors it was decided to leave the incorrect part in place as it might change the sound from units that were already out in the field
