[quote author="Rob Flinn"]I was just asking because in your other thread about changing the input transformer the last thing was that you were having problems with it clipping, & I was wondering if you had resolved them ?[/quote]
Oh yes, you're right!
The clipping problem is because the input attenuator has wrong resistor values: the in Z that the soundcard 'sees' is too low, so it clips at high level. I was using this: (R37 and 39 are 301R actually)
I think that raising R36/38 value a bit will solve that problem.
[quote author="PRR"]I wrote a long theoretical reply, but, ya know.... for a two-6V6 line driver, the color of paint on the OT probably makes more difference than any UL connection. [/quote]
Oh could you please show the link to your article?
[quote author="SSLtech"]Not knowing much about the Sta-Level -and not being overly concerned with authenticity- I was wondering what the cost-effective input, output and power trannies would be...[/quote]
As you can see, I am using a 1:1 input trafo, a Lundahl LL1540, with good results, so you can try any 1:1 of your favour.
As for output trafo: I am currently using a Hammond 1650G, 6K6 p-p wired for 250R secondary, with satisfactory results. Someone is winding another OT for me, it is a 8K p-p with ct in each primary, so I can experiment with UL connection (even if 50% is objectively too much).
As a result of my recent tube-limiter building frenzy I seem to have contracted a case of 'must-buy-exotic-tube' syndrome, and I have a 6386 here, and I was considering building a Sta-level clone to house it.
Great! Is it a genuine one? You could post the characteristic curves to check for substitutes.
I am using some 5749 (6BA6) that I bought some time ago, they seem pretty similar to the 6386 published curves. Here is what I get with these tubes:
I also bought some 6BJ6 (Sylvania), but I feel the 6BA6 curves are closer to the 6386.
Unfortunately I have never had the pleasure to get my hands on genuine 6386's, so I cannot make any comparative listening test.
If anyone has some experience with that can post impression.
Thank you,
Val.
