amplexus
So here's the sitch.
We have a system installed in a studio where there are a number of movable 'podiums' which contain a headphone amp, and hold a tablet which wirelessly talks to an X32 for artist cue mixing. Audio and power are conveyed to the podium via a shielded CAT5e line. A 20A 15Vdc SMPS resides in a machine room, and DC is distributed around the room to various patch panels.
I am adding boards to each podium that will take our 15Vdc distributed power, and regulate down a 12V rail for the headphone amp with additional filtering, and a 5Vdc line for USB charging to keep the tablets charged during long sessions.
There are two main 'hurdles' I am attempting to overcome- First, that the 12VDC rail for the headphone amp is dead quiet and free of switching noise AND any induced noise that the tablet charging might throw out which is seeming to be an issue with our current 'dumb' system, and that switching noise in the main distribution line is quiet enough not to contaminate the audio lines while they travel together for 15ft in the CAT5 cable. Second, that we can reliably have the mainstream range of devices that may be used always go into fast-charge mode either 5W or 10W
I will add a hefty amount of CLC filtering at the SMPS to clean up the output for a start, and I'm using an SMPS that can function correctly at no-load. What I've got is the following circuit to go into the boxes to deal with the headphone amp and Vbus rails as well as the charge port controller chip and USB connections. What I am hoping is if someone can tell me if i've done enough/too much/wrong things to decouple the charging rail from the headphone rail, and what other considerations I might need to keep noise to minimum or zero.
Or if I'm just way off base and need to rethink the whole board
