Hi All,
I am considering using a DB25 switchbox so that I can switch between two interfaces that use d-sub 8 channel looms. My concerns is what sort of issues should I expect and is it solvable.
I read online that I should use specific audio DB25 to DB25 cables(from interface to switchbox) as the specific audio DB25 cables keep each shield with each channel hot/cold unlike computer cables that may keep the shields ungrouped.
What sort of issues are there though when it comes to the switch box - noise, hum, crosstalk, etc?
If any issues, can these be resolved?
Is there a cheap alternative to making this routing concept work? I was considering possibly doing it manually with DB25 short extension cables from the interfaces and manually swap the d-sub loom it is connected to but then, would there be an issue from the connection point? Also, I prefer switches as having to reach back at the cable may start to become tiresome.
Thank you.
Thank you.
