tardishead
Thanks Doug that's great
So I paralleled small caps to match the capacitors on the 2 units and they are sounding a damn sight closer now.
Almost identical in the top end.
I think the silver mica caps sound good but maybe a bit brittle. I figure as I have it apart I should try get the best sound possible. Any recommendations for really sweet NOS caps? I was going to try k40y9 for the 2 larger ones. What to use for the smaller ones?? Polystyrene? 10nf I can find in k40y9 but nothing smaller. I can find Vit Q down to 4.7nf but insanely expensive.
Slightly strange thing happens - when you have bass boosted max as you bring in the treble the bass gets attenuated a few db but not the other way round.
I thought it was supposed to be lossless!
I am testing with some neve line amps as gain makeup with no input output transformers for the EQ
I have the output of the eq terminated with 600r but nothing across the inputs
Also one unit has about 3db more bass when no treble is dialled and bass is max but they seem to be the same as more treble is added
