martthie_08
I have a V76 which has been giving me some troubles, it makes a kind of farting noise every 5-20 seconds. I will get a sound sample up this evening, maybe someone knows what could cause this? I would guess either a tube problem or dried out electrolytics, but have no idea on how to trace this down. I hope it is not a transformer dying out on me, that would be a big problem. Speaking of transformers, one of the trannies (far right on the first pic below) is sitting loose and moves around in the housing, is this a serious problem?
The unit seems to be a very early unit, I got a schematic with it which I can scan tomorrow (haven't seen this one on the net yet), it is close to factory stock condition, all caps (except one) seem to be original. While I'm fixing this problem I'd like to do some "restauration" and replace the four big 32uF HT filtering caps, which you can see in the pics below. One is on the main circuit board and three are upright in a filter daugher board. I guess it is advisable not to change any electrolytics in the signal path - or what do you think?
Here some pics:
The main board:
There is third board which sits in vertically.
This is front, notice no "/80" on the logo, but the 80+300Hz low cuts are there.
any suggestions greatly welcome!! cheers, Marten
Here some pics:
The main board:
