[WORKING OUT THE CONCEPT...........FINISHED]
[COMPONENTS PURCHASE...................FINISHED]
[MECHANICAL DESIGN............................FINISHED]
[PCB DESIGN................................................FINISHED]
[UNIT ASSEMBLY........................................FINISHED]
[TESTS AND ADJUSTMENTS..................FINISHED]
[FULL DOCUMENTATION WRITEUP - WORK IN PROGRESS]
I will be documenting my TAB V76s preamp build in this thread.
Here's what's given:
I'm going to provide for an optional simulated inductor schematic for the HPF. This will allow to use an IC instead of a real 100Hinductor (which is pricey).
My main concern for now is the PSU. I have the regulated HT part designed and it should hopefully work fine. I've thought about the heater section a lot. Unfortunately, it's not possible to put heaters in series and use a 12.6V supply because of different current draw of the tubes. CCS is also not very elegant because of the same problem. My current plan is to use an LDO (probably 1085 type) - with the right input voltage it will dissipate around 6Wt which should be manageable in a large enclosure.
Now, for aux supply I need to have 48V for phantom, +/-18V (or +36V) for ICs and VU buffer, 24V for relays (some of them can be combined to work from 36V) and 12V for DI. I haven't done the exact calculations yet, but I believe that 48V 0.3A should be enough for all my aux needs if I generate all these voltages from a single 48V source. However, since the main power is consumed downstream (+36V and +24V are the main consumers) this leaves me with approximately 12*0.3=3.6Wt of wasted power right of the bat. So I'm leaning towards the +36V being my main aux feed, and getting +48V from a doubler or tripler.
I'll be finalizing the design in the coming weeks and I'm planning to start ordering parts and laying out PCBs shortly.
If any of forum members have any thoughts or ideas, they are welcome.
- Height - 3U
- Transformers and chokes - Sowter
- LPF - removed
- HPF - uses either real or simulated inductor
- DI option - switched between FET buffer fed into the input transformer or direct input to the first tube grid.
- Input gain switch - split between pad section and resistor feedback network section. This allows for using a single pole switch
- VU meter - buffered from the output transformer primary to keep galvanic isolation intact
- All switching is made via relays
- PSU - DC regulated HT, heaters and aux supplies
