I'm moving on with the PCB design, and I'm currently finalizing the PSU section. I've settled on the switcher for heaters, and a basic LM317 linear reg for auxiliaries. HT will be a neat circuit from Merlin Blencowe's book (not sure I can post this circuit here - haven't seen it published anywhere on the net).
With the SMPS section, I have 2 questions. Since this is a buck topology, it's main noise is on the input. I had successfully used PI filters and CM chokes to combat the noise, but those were all SMD components. I aim at the TH components for this section though, and I've stumbled upon these TDK hybrid chokes that have a rather large stray inductance that allows to build an LC filter "integrated" in the CM choke.
I've never used those, but given the numbers from the datasheet (200 uH stray approx.) this should be enough.
Another question is the output filter. Currently, it's a simple LC filter. Do I need to use cap multiplier in that position instead?
![1652465395710.png 1652465395710.png](https://cdn.imagearchive.com/groupdiy/data/attachments/45/45925-88edb3f2eb4097586f352ec94817856d.jpg)
