Winston OBoogie
I think the use of pentodes goes hand in hand with superior winding techniques. It allows the use of high ratio xfmrs, cause low Miller cap.
Without a doubt. Some of those input transformers were 1:30 and still had excellent frequency response.
I enquired about purchasing a couple of 1:10's (CTV72/1) from a company that have the documentation and means to wind them still, and it 'ain't cheap! About 4 -5 times the cost of a very nice Lundahl. But it's a 5 chamber bobbin, not your typical jobbie, so that stuff costs money.
Too rich for my blood though.
I would like to see a comparison of a pentode with a cascode. Noise ought to be better with the latter... I don't see anything against cascode, except maybe the need for slightly higher B+.
Yep, your B+ would generally be higher by your artificial screen grid voltage so, probably in the 60v - 90v region.
Pick your operating point/anode load using triode curves, then shift everything to the right by the cascoding voltage for your pentode "knee".
Using inexpensive pentodes (6BR8) strapped as triodes, I was seeing about 2 - 3dB better noise figure
(over a single pentode) with 2 of those triodes on the bottom of the cascode. No partition noise in the equation now of course, so a little of the improvement no doubt came from there.
