Hello everyone.
I am in the process of recapping/repairing my old API 2488 desk.
While i had all the modules on the bench I thought i would take some pictures to share with you all.
Hope you enjoy them!
API 528 Input module:
I have not checked if this is the same as a 512 preamp, must be very similar though.
Can post the schematic if there is any interest.
API 550 Eq:
This is the original early version.
API 550A-A Eq:
When i looked through all my 550a eq´s i found out that there is actually 2 versions.
This is the earlier 550A-A circuit board.
The later 550A-B below has some circuit changes, and a larger IN switch.
True bybass maybe?
API 550A-B Eq:
This is the later 550A-B version.
Cool that there is different, original opamps in all the eq´s!!
API relay board:
Need to replace those old Siemens relays!
Does anyone know a source for these??
There is a Tyco replacement, but its very expensive here in Sweden.
Would love to find them cheaper somewhere else.
API sum and boost amps:
These are sum and boost (after fader) amps for the stereo bus.
Nice opamps and iron!!
Regards,
Dennis
API 550 Eq:
API 550A-A Eq:
True bybass maybe?
API 550A-B Eq:
API relay board:
Regards,
Dennis
