The FuzzFace response varies enormously with the impedance of the source it is connected to. E.g. when connected directly to a guitar, the pick-up inductance combines into a low-pass filter resulting in aggressive distortion of low strings and moderate crunch on treble strings, which is not always desirable.The resistor is 10K not 1K as previously stated.
Inserting a pedal, which has a constant ohmic impedance provides a more balanced effect. Now, if the output impedance of such pedal is very small (like a buffered output) the input capacitor in the FF creates a high-pass filter, which in turn alters the response in the opposite direction, making it very trebly.
Varying the output impedance of said pedal, via a potentiometer or switched resistors, provides a range of tonal variations.
Is there an optimal value? It depends on personal preferences, each one his own...
BTW, Brian May's sound is the result of using a treble booster with the same characteristic response vs. source impedance, so his Rangemaster combines input low-pass due to the pick-up inductance and high-pass due to the input capacitor, for a resulting midrangey band-pass.
