WA-414 upgrade with CK12 ?
Avgatzeblouz
Montréal
Hi everyone, according to mail excahnges with Warm audio, their WA-14 is a 1:1 replica of the 414EB circuit. I was wondering if the components are close enough that putting a Tim Campbell or OPR capsule in it could really turn it into a 414EB ?
Thanks to anyone that could have an idea about it.
If you already have it then it's worth a shot. I wouldn't order one with the intention of putting in a better capsule though. I don't know if I'd believe it's a 1:1 copy though since it's missing a few features like a hyper cardioid polar pattern.
I'd reckon that's because 3-position toggle-switches are more readily available (and as such, cheaper) than 4-position (or more) slide switches.
That makes a lot of sense, I'm just not sure I'd buy it's a 1:1 copy. I'm sure if anyone takes one apart who actually knows they're sh*t they'll give a much more accurate opinion.
FWIW OP a used SE T2 can be found for like $350 if you're patient, I have no idea how close it is circuit wise to a 414, but it'll give you an incredibly similar body and the same polar patterns. I've got one on the way I got for about that price, I'm debating on throwing in the Maiku CK12 I bought, or waiting like a month and buying a CT12 with my tips.
Jim50hertz said:
This
Abgatzeblouz can you clarify?
I think they copied the first version, non P48. It should be easy to check, I think the P48 does not have the DC-DC converter. I'll get back to you guys.
If you are patient enough you can still score C414EB and EBP48 for around 500 Euro, which is about as much as the Warm Audio interpretation cost, but in the end you have the real deal ;)
Good source at the moment are france and italy.
This is encouraging as eBay prices in the U.K/EU are far more than this
Five years later I'm curious if anyone here has dived into this circuit to confirm it's relation to the inspiration. I'm interested in something EB-esque and have a Beesneez brass cap sitting around. Seems a better option than dropping near a grand on an EB if it's close.
Yes, had been considering the Vamisound kit. It is doubtlessly a more faithful circuit. Ended up taking a leap on the Warm since Guitar Center had a barely used "Classic" (i.e. silver) one for $279. Since it's GC I can always take it back if it's not a good fit.
It's kind of silly, never used a real EB myself, but have used numerous modeling mics and modeling software and both the UA and Antelope emulations of the EB are always the best for my voice of all options, so I figure it's worth a shot.
Will crack it open when it comes and compare to the EB schematic and update here with pics.
As promised, some pics. Haven't had time to compare with the EB circuit, but it certainly didn't knock my socks off with the stock capsule. That said, at a glance and being a novice, the circuit looks better than I expected.
I'm thinking about going dumb with it and dropping in my CT-12 to see how that sounds. I realize it's ridiculous to put in a capsule that's worth twice what the mic cost, and I'll probably pull it once I get my PTP 251 built, but why not give it a spin.
Without further ado:
Updated with observations: (my novice observations aided by ChatGPT)
EB Comb (Original Version)
  • Amplification stage transistors:
    • T2: 2SK30A-R (JFET)
    • T3: BC413C (BJT)
  • DC converter transistors:
    • T1: BC183B
  • Output transformer:
    • 1.33:1 ratio (low step-down, maintaining higher output level and providing a vintage, full-bodied tone)
EB P48 (Phantom-Powered Version)
    • T3: BC413C (BJT)
    • T1: BC413C
    • 6:1 ratio (high step-down, reducing output and impedance for compatibility with modern preamps)
WA-14​
    • Q4: 2SK118 (modern JFET with improved noise performance)
    • Q3: BC550C (modern low-noise, high-gain BJT)
    • Q1: BC550C (modern low-noise BJT)
    • Q2: Likely 2N6510 (high-voltage NPN transistor)
    • 3:1 ratio (mid-range step-down, providing a balance between vintage warmth and modern performance with increased headroom)
View attachment 138820View attachment 138821
View attachment 138822View attachment 138823
    • T3: BC413C (BJT)
    • T1: BC183B
    • T3: BC413C (BJT)
    • T1: BC413C
WA-14​
Looks surprisingly nice! Could that be a Teflon board? Same capsule than in WA-251. It's not the worst.
ChatGPT is always confused about transformers. I don't think the ratios have anything to do with vintage tone or compability with modern preamps (if it would, it should be the other way around), but the circuit topology. If the 1.33:1 ratio is even correct. Can't find info about it, but it's in the right ball park at least I think.
Also, I don't think there's any DC converter in EB Comb.
