Is it based off the China microphone circuits like the Apex 460?
It seems so, kidvybes about the Alctron MK47:
"...yes, both Art and Apex are Yorkville brands, and the T4 appears to be a re-packaged
Alctron MK47...the circuit in the MK47 is the same as in the
Apex 460...the capsule is a 35mm K67 rather than the 460's 32mm K67...the T4 is an excellent candidate for modding,
...a lot of the modders/DIY builders are using the
Alctron MK47 body to build custom 47-inspired mics...Brian does that as well...I have an Ioaudio MK-47
U47-recreation built using the same body/headbasket:
http://store.studio939.com/product/m...phone-body-kit
...I've noticed this mic by the Hamiltone Guitar Co. on
eBay lately, which also appears to be a rebranded
Alctron MK47...not sure if they further modify it, but at that pricepoint I would hope so:
http://www.ebay.com/itm/Hamiltone-H4...-/191636016071
from your link, gearslut cdkelly about the role model of the WA47:
"As for how the mic was 'designed', it was not designed for a 5751. It is largely based on an Asian mic that has been on the market in China for many years called the Alctron MK47. Those mics have always shipped with a Chinese 7025 (mil spec 12AX7), and that's what it is 'designed' for. The work we did at Warm was merely to import this mic and re-work the PCB layout to reduce noise and improve sonics as much as humanly possible (putting in a much better transformer, better tube, better capsule, upgrading component quality, tweaking the voicing, taking off the PCB solder mask and moving around some stuff on the boards, etc; but the inherent 'design' itself never changed. At the heart of it, its still the Asian 12AX7 circuit that we found."
Here is the original Alctron MK47
https://de.aliexpress.com/item/32765350862.html
