Some specific parts I need for various restorations, not uncommon parts, but also proving not to be the sorts of things that end up on ebay. If you've stripped some '30's military gear, you might have this stuff lying around. Anyone have anything, get in touch. Thanks.
Six pin sockets. Also need the insulating wafers that go between the sockets and the panel they would mount to. Note the contact construction of the socket on the left, that type preferred, will take either. Mounting centers 1-3/8". Mounting between pins 2-3 and 5-6.
Two shield types, and grid cap type. Also need the shield mounts that bolt to the chassis. Need some of both shield types/mounts. Looking for this particular style of grid cap, sized for 6 pin tubes, as opposed to octal which is smaller.
Shield 1-5/8" x 4-1/8" with top cap 1-3/16" x 7/8".
Shield 2" x 4.5".
Two switch types. First momentary like this; 1/2" round 3" long DPST MBB:
….and another… need eight SPST MBB, one DPST BBM:
last but not least, a meter case. Primarily need the metal cover piece, so trashed bakelite with metal remaining would work.
Shield 2" x 4.5".
