Inadequate capacitive bypassing
Not that capacitance directly in parallel with a zener has limited effectiveness to begin with, but yeah - RC filtering downstream is to be desired.
yep, the capacitance with the Zener impedance would be the first RC time constant, but better add some more R before the C.Not that capacitance directly in parallel with a zener has limited effectiveness to begin with, but yeah - RC filtering downstream is to be desired.
Sure, the zener is a noise source. However, if this noise were a structural problem in this design, then any KM84 would have this problem. But this is not the case because Neumann designers were clever enough to design in an RC filter, which is R7 (10k) and C5 (4.7uF) in the original KM84 design. AFAIK, the WA-84 follows the classic KM84 schematic. Furthermore, the circuit has some PSRR, all-in-all attenuating the zener noise by more than 130 dB. I measured the noise of a 24V zener and it amounted to 28 uV. (No use trying to measure that with an oscilloscope....) Of this 28 uV, only 3.2 nV remains at the mic output, which would equal a noise level of -35 dBSPL. Absolutely a non-issue.yep, the capacitance with the Zener impedance would be the first RC time constant, but better add some more R before the C.
Great! Was this the same Zener and mike with the problem? Keep an open mind when troubleshooting. Obviously, if this is a series production unit made in the thousands, this would not be a design issue. However, things can fail.I measured the noise of a 24V zener and it amounted to 28 uV.
No it's not the one with issue... Jan has not got it since it's here with me.Great! Was this the same Zener and mike with the problem? Keep an open mind when troubleshooting. Obviously, if this is a series production unit made in the thousands, this would not be a design issue. However, things can fail.
No, not the same zener. The WA-84 has through-hole parts. Mine is the SMT type BZX384-B24V that I use in my KM84+/++ designs. But I don't expect a wired version to suddenly have more than 300 times higher noise, which would bring the self-noise of the head amp close to the assumed capsule self-noise.Great! Was this the same Zener and mike with the problem? Keep an open mind when troubleshooting. Obviously, if this is a series production unit made in the thousands, this would not be a design issue. However, things can fail.
How to remove the coating ??? Isopro Alcool does not...I'm just speculating now, but maybe the conformal coating applied to the PCBA in the High-Z area could be the problem, instead of the solution against moisture related issues. If the board wasn't cleaned properly before coating application, and if it was stored at very high RH, tracking could still ocurr between PCB surface and coating. Tiny amounts of ionic remnants could still cause tracking in combination with 0.1-0.2% moisture content of the PCB laminate, even if coated. I've seen this happening in field return products in my professional life. So cleaning an removing the coating could indeed be the solution.
Not allegedly but in reality. You can test this for yourself by using a polystyrene in place of a capsule. I found this circa 1980 and Guru Wurcer did so more recently. I think he mentions it in his Linear Audio articles.Mind you: remove polystyrene capacitors as they will be destroyed by IPA, Aceton or this cleaner. Having said this: I now see the WA-84 has such capacitors, so perhaps this already happened... I'd replace them by C0G ceramic capacitors. ... , allegedly polystyrenes are sensitive to microphonics. Add to this the chemical sensitivity and there is no reason to use polystyrene caps. Have you tried replacing the polystyrene caps already?
Nop, swap with the other one (which works in the other body) and still failurePolystyrene caps destroyed by IPA you say? Anybody seen one?
Stupid question but - its not the capsule, right?
2-3 times and 'till the next time... I mean before going recording > test > issue > cleaning > recording ok > back home - mics back to storage. Then next time 50% ok 50% issue. The mics are stocked with silica gel close to the capsules (as any of my mics)How many times cleaning helped this problem before? And for how long?
NopHave you tried the hair dryer?
I can give it a try (and change that polystyren caps for C0G/NP0)Here in Auchans there is that "Pikko Universal Diluter", 500ml plastic bottle for like 1.50 euro. A mix of 10 different solvents that you smell 3 floors down but yeah, you may call it hi-z low noise magic elixir And thats what you need to save your polystyrenes from!
Hi @ricardo , do you think the ones in pict attached would do ? (470pF & 5pF) Mouser charges 20€ for 4 caps (2€ total) when Banzai music only charges 9€...And polystyrenes often die when flow soldered too. These days, there's no reason to use polystyrenes when COG/NPO ceramics are cheaper, more robust & quieter.
Knowing the issue is certainly in the high Z area (and that I already changed the 1Go to ground) I must change the 2 polystyren caps to pursue "my procedure"But if you have an existing mike that's OK, just leave them in. The microphony may be part of the sound you like
If a reputable supplier advertises them as COG/NPO, they will be OK. I think both Mouser & Banzai are in this categorydo you think the ones in pict attached would do ? (470pF & 5pF) Mouser charges 20€ for 4 caps (2€ total) when Banzai music only charges 9€...
Aha. On the Digikey site, search for 134-8698-ND.The Digikey link does not open...
