What if you prefer the tants over film or electrolytic?
@EmmathomFor instance, J. Hiraga advises and uses Muse BP in his low signal path boards (pre RIAA, Dac, etc)
Ok ok Per... some rules are really gold ones like "I never change a good capacitor" and you're rightI will try to rate my choices here - but beware there are a number of exeptions - depending on application :
Audio :
1) Ceramic NP0/C0G - If the size of the case makes sense + can get them.
2) Electrolytes if I need big values and they are followed by something where leakage isn't critical - usually OpAmps.
3) Filmcapacitors where I connect the Anode of a Tube to the next stage (passive or active). Manually mounted.
As most of my Production stuff is guitar pedals - NO Filmcapacitors, as they usually degrade really Badly in a Reflow-Oven.
4) Tantalum - when I need a big value and the above isn't an Option - like leakage + they will see about a third of their rated DC Voltage over them.
I would NEVER use a Tantalum if it will see zero Vdc. - as it will distort badly and sound ******.
Power Supply :
1) Electrolytes.
2) Unless the size is small enough to consider Ceramic SMDs.
3) Tantalum - if it makes sense - this can be in relation to price / avaliable parts (defenitely a reason during Covid and for some time after).
Oh - and in repair situations - I NEVER change a good Capacitor ...!!!.... no matter the type. If the value and ESR is good and I don't have any leakage that give me problems. And just to be clear : I change a lot more Filmcapacitors than I change Elelctrolytes in old Tube gear - simply because they leak current into the next stage, and this can destroy the Tube that comes after .... Of cause old Oil- or Paper- capacitors are a lot worse (like what you find in old Teisco Amps).
So why do I recomend not changing the Tantalun in your Microphone - there isn't any room for one that will be an improvement. The Electrolytes you keep on suggesting might work as well as the original Tantalum in this application - but I have a hard time seeing them as an improvement. The Transformer might not care much about any DC Current through it in this application or it might react just as bad as those old Tradania wonder ones did.
In this regard I recomend listening to Jakob E. as he has much, much more experience than me, in regard to Line and Microphone Level Transformers - like how they sound and if they distort in a good or bad way
I also admit that sometimes it better if you make your own experiences - simply to learn - but keep an open mind, like did it truely make a difference or is it just because people tell you it will do so
Per
ps I didn't recomend 1µF 50V electrolytes in your application - it was an example from my previous work.
Geoff Tanner (Neve) always warned not to replace tantalum capacitors with aluminium ones...I'm pretty convinced that tants are important players when it comes to making a sontec clone sound like an actual sontec..
It's not a lot, but it's certainly there
"Those tants aren't there without a reason", he used to say...
/Jakob E.
I've shared this story before. Back in the 80s CBS granted me a CX (vinyl noise reduction) license so I could make a CX record playback decoder kit. In the course of studying the licensee package I saw the encoder design schematic and it used a tantalum capacitor in the side chain for the dominant encode/decode time constant. Tantalum caps are known to have high dielectric absorption (DA). In the specific application of a side chain being charged and discharged with different attack/decay impedances, DA could alter the attack/release envelope. To make my playback decoder as accurate as possible I used a tantalum capacitor in the CX kit decoder side chain too.Geoff Tanner (Neve) always warned not to replace tantalum capacitors with aluminium ones.
They were only 'better' cos less leakage and smaller size. Today, Lo-Leakage Al. electrolytics rival Tant leakage and size too.If you have a unit from the 70's or 80's were all the electrolytics in the signal path are tantalums the reason is that they performed better than aluminium back then.
I have some correspondence with Guru Scott Wurcer on the less well known sonic 'features' of various capacitors for LN use. Most (all?) polystyrenes are microphonic. Tants and the Golden Pinnae Micas introduce noise. MicBuilders members have confirmed the wooshy noise with Tants. used in the signal path at capacitor mike levels.That's not the case anymore BUT they still have som benefits so if you have a circuit with a mixture you should probably keep the tantalums. And of course, if you want the same sound as the original unit keep the tantalums.
That Zener is a noise source, a sharp knee zener (low Z) has more noise than the hi Z. Inadequate capacitive bypassing would feed that noise right into the signal. Check with a scope.Hi
I disassembled my broken WA84. As I already said it suffers from noise & cracking. The mechanical aspect of this microphone is crap. The "tube" that receives the capsule connection peak is just soldered between the 2 PCBs and it is painful to unsolder / resolder. The PCB itself is not quality either and a kind of "mud" recovers the components and melts with the solder when you try to re-solder the components.
In short, I redid all the soldering (re-melt them) and removed the 1uF tantalum in series to measure it. It is good. I then changed the jfet (J112 installed despite the fact that it should be a BF245 according to some web review) for an MPF102. No improvement ...
One thing to note is that by dint of unsolder / resolder the PCBs they start to get damaged...
So I decided, next time working on the microphone again, to change all the components (except the OPT). On this occasion, and against all odds, I will replace the tantalums with chemical but quality ones (Panasonic FC or Elna Silmic II). According to the KM84 schematic, all 5 capacitors (except polystyren & Wima MKP 100nF) are 4,7uF and 50v is ok for coupling as for filtering. In another hand, Banzai (https://www.banzaimusic.com/Tantalum/) does sell tantalums (can we rely on their quality ?)
The question is: should the J112 be replaced by another reference? and if so, which one do you recommend? On the original schem. it is said 2N3891 or J113... or similar (?). I got a stock (~30) J113...
Regards
