Big update on gain reduction LED meter v2.0
Sorry no vid at present.
I have completely reconfigured the circuit so everything shown in the video and accompanying schematic for Gain reduction should be disregarded. This has been a great learning exercise for me!
Ok, to summarize: The photoresistor (1of2 in t4b) has been placed in the upper (or can do lower for a falling appearance) leg of a voltage divider with Vout as the input to ONLY an LM3914. The Output meter benefits from the opamp buffering, but the GR does not require an opamp and even though it works like in video to show peaks, it does not "hold the needle" visually with a steady input tone.
I have the Lm3914 in a "variable voltage indicator" configuration which uses very few parts, maybe 4.
Now when inputing a steady voltage signal and adding compression the "needle" (led= dot mode, leds=bar mode) remains fixed until I stop the input signal.
My next step before final assembly off breadboard, is getting the calibration just right.
I took a bunch of measurements of when the photoresistor starts decreasing resistance for a given strong signal (I know that is all variable and that's what's making it tricky to calibrate). I feel the LA2A starts adding compression with the knob around ~20, again I know that is dependent upon strength of input, so I am trying to ensure that that gets represented with a "blip" on the first LED. However, I need to adjust the range because when I adjust for first LED light on at around 20 on the knob, I get to maximum level when I raise the compression knob to around 60. So this is where I am fiddling
With the LM3914 in dot mode, it makes the visual of the deflection of the "needle" (by needle I mean led in dot mode) more like the front grill of Kitt which looks cooler and saves mA
tbc!
If I post all my new schematic in Drawing board with a title "How to add LED meters to LA2A" would someone pretty please chime in with improvements or tips/ range adjustment info for the LM3914? Otherwise, I'll just keep plugging away and post a final result here later. Hopefully I don't need to switch to a multiple quads comparator circuit, to get a satisfying result, but I see that would allow very fine tuning...sigh...
2.0! (really much better)
Andy
P.S. I've got to say, simply viewing the Output LED meter and listening is really all the aide that is needed. Getting this GR display just right will be extra eye candy.
