darkus
Hey guys, this is my first post here! =)
I just got an Aphex Compellor 300 AX (the oldest model i guess) for crazy cheap. While it seems to work well compression wise, the knobs and settings between the two channels are off.
I first opened the device and set the inputs and outputs to +4 with the internal jumpers. I also double checked my interface outputs were +4 too. Then i hooked it up with my interface and started to send sine waves through it. With the device bypassed, channel 1 was 10dB louder than channel 2.
This problem got fixed when i switched the feeding output for channel 1 from my interface to -10dB. Still, there were few desibel difference.
I also tested the unit with some mixes ive been working on. I had to match the channels with sine waves since the pots are really off too. Channel 1´s input is weak and channel 2´s output is weak. Here is a pic where you can see what im talking about.
https://dl.dropboxusercontent.com/u/23190863/comp_cali.jpg
Im thinking if this has something to do with the trimpots i saw inside this unit on both channels. They possibly bias the VCA´s?
Other than the channels being off with each other this unit sounds awesome. Here are some test mixes i sent thru it. Compellor is my only processing in the 2bus.
Bypassed: https://dl.dropboxusercontent.com/u/23190863/Compellor_Bypassed.mp3
Unit On: https://dl.dropboxusercontent.com/u/23190863/Compellor_On.mp3
I really want this unit fixed (and maybe switch frontpanel knobs to stepped pots for easier channel matching)
Is there anyone to help me? =)
-Markus
-Markus
