I designed the backplane PCB for the EZTubeMixer nearly a decade ago. It has gone through several variations and upgrades but the core layout is the same. One thing that has always bothered me is when modules sliding in card guides mate with the backplane mounted connectors the module moves up and to one side very slightly. It seems to make no difference to the performance or the force required to insert or extract a module. When I designed the backplane there was some ambiguity over the exact positioning of the connectors with respect to the fixing holes that attach the motherboard to the Eurorack extrusion. The centre line of the connector is 8 thousandths of an inch offset from the centre of the the connector's fixing holes. From the best connector and Eurorack data I had at the time I determined that the centre line of the connector should be aligned to the motherboard fixing holes. The connector fixing holes are therefore 8 thou/mil offset from the motherboard fixing holes.
I recently had cause to update the motherboard design so I revisited this question but this time I decided the fixing hole of the connector should be aligned with the motherboard fixing holes. This means the connector centre line is now offset by 8 thou/mil. I have just finsihed assembling a new motherbaord to this design into a Eurorack case and fitted the card guides. Now wehn I slide in a module it just goes smoothly striagh into the motherboard connector; no jogging or sideways movement of any kind. What a difference 8 thou/mil makes.
