Hello folks,
In an effort to find the easiest and cheapest parts to do things like switch LED's on in circuit etc, I would like to discuss and share what transistors people are using.
Sounds silly, but I hope that some of you may be using low cost transistors for switching etc.
So, I'll go first.
I use PN2222 transistors for switching LED's and relays. They are cheap ($0.05 at mouser for 1) and can handle the current easily (can support up to 600mA)
They are also available in surface mount too.
Can anyone suggest a MOSFET or JFET in the same price range?
Also, can the base-emitter pins be used as a diode for simple rectification?
/R
/R
So, I'll go first.
/R
/R
