I tried changing the capsule once in my Rode. After that the sound was barely hearable and htere was striogn statics,. It was broiken
While I am no expert, I worry you are going about this all wrong. After listening to some of your work on YouTube, I suggest you acquire an inexpensive Tascam TM-80 which has received several positive reviews on this reflector. Use it exclusively and consistently as you continue to develop and refine your microphone and voicing technique, all the while generating a larger, more lucrative portfolio. Later, you should ask the producers and recording engineers using your work in larger, more complex productions, what microphone would be bested suited for the task. After all, they must merge your work with that of other talent to produce a cohesive, consistent result. Asking us now what they will want you to use later seems misplaced. An affordable microphone today will save your hard earned brass for the microphone specified by engineers using your voice with other material later. That seems a better plan to me. Just MY take. Your mileage may vary. James
