Ahh, I see. Maybe some Melcor's like I just finished? Funny thing, I measured about 8mv on mine also.
There can be some confusion between gain trim and offset trim. The gain is controlled by varying the input resistor, so your ratio between the r2/r1 formula is changing the gain. There should be a terminal for this on the card, if you are still using it.
The offset trim is say a 4.7 k resistor if I remeber correctly, at least on my board.
here are some pics:
This part of the circuit sets the gain of the amp. I used a 100k pot, btw, not the 1k, which is shown on a few schematics, which I believe is wrong.
x
This is where you trim the dc offset:
OK, now for some more confusion. I have seen at least three different output arrangements for the API stuff.
Cap output, which means dc offset is not an issue.
Direct output, thatt is no cap, no resistor, just a piece of wire leading to the output tranny.
And a cap/resistor combo:
x
The good news is that I tried all three, and could hear no difference in the sound, so why not use the cap and be done with offset problems, ehh?
cj
z
