Stagefright13
OOPS! http://www.expataudio.com/
SSLtech said:If you have one built, and haven't noticed any hum, just try turning it on, and listening to the output with no signal present. -Turn it up until you hear the hiss. -If you hear hum in with the hiss, that can be eliminated.
I think that builds which have more current consumption might also suffer more greatly; so if you have turbo, dual sidechains, relays, illuminated buttons, bargraph metering and lord knows what else, you might be causing more ripple on the lines, and the problem with the existing GSSL layout is that any modulation of GROUND reference tends to get picked up at the current-to-voltage converter stage immediately following the VCA.
So if you only hear 'inky-black silence' when you wind a ton of gain onto the output of a GSSL, you're in luck.
Kingston said:But BOM doesn't enter the equation as it's not possible to fix this with simple parts replacements. This is a problem with physical traces of the PSU area. The noise is polluted to the board from the VAC connectors next to the rectifier, and because the onboard filter cap + rectifier traces let some of this noise through. CRC board ensures this is cleaned before it ever enters the board.
So what are you using, Jung regulators?Kingston said:PS. I don't, or would not use the CRCRC. I don't like the GSSL stock regulator "application note" set up one bit.
jackies said:So what are you using, Jung regulators?Kingston said:PS. I don't, or would not use the CRCRC. I don't like the GSSL stock regulator "application note" set up one bit.
This is cool!Kingston said:I actually did test Jung regulators on a GSSL.
For what it's worth, I built two identical turbo GSSLs recently, Both with 78xx/79xx and CRCRC.Kingston said:PS. I don't, or would not use the CRCRC. I don't like the GSSL stock regulator "application note" set up one bit. It's something I would only use for simple non-critical stuff like LEDs and relays. Also, a completely external solution is better for a PCB where ground traces are known to cause problems and distribute noise in unpredictable ways.
