After moving cross-country last year I've built my lab into one corner of my new mancave.
My Aeron is at the computer/music desk. Wheels suck on carpet. Upgraded flooring is a future project. The old wooden chair isn't bad. Came from my grandparents' house, so sentimental value. Better than the folding chair i used to use.Looks good, you just need a better (comfortable and with wheels) chair
I decided to step up my spraying game so purchased a 12V powered sprayer and strapped it to my zero turn.
It is kind of disappointing how optimistic they all are about their specifications. They claimed it would spray 25' vertical. It was not even close. I just replaced the 60psi pump with 120psi pump and now it makes the 25-30' vertical, but still not high enough for my trees. You will notice the pump is mounted at an odd angle because the higher power pump had the goes-in and comes-out ports reversed. I was able to grab 2 of the original 4 mounting screws.
My next step is to mount the short sprayer wand to the top of my old extension pole ( in the picture above) with spray hard wired on. I just ordered 30' of hose tubing, and an in-line cut off valve, so I can control the flow from the bottom of the extension pole. This won't get me to the top of the trees but more than half way there..
PS: A commercial sprayer to do the job from the ground would cost thousands of dollars and I'm still cheap.
What woods are you using? Kit or scratch-built? I like the sound hole design.Archtop acoustic bass (with underbridge piezo transducer) - coming along, but a long ways from being done.
Wow, our tomatoes and peppers are just coming on - very different growing seasons I guess.
They say you should have the water already boiling when you pick the corn - we weren't that prepared. I ate it off the cob for the first time in about 35 years - mmmm. I had to start cutting it off before eating - when I kissed her good night, one of my daughters told me my beard smelled like vomit after I ate corn. I had my wife smell it today - she said it was fine.
