...if it's a phono EQ curve, then you'll sound rather muffled going theough it... the current RIAA curve has a 40dB gain range diferrence between 20Hz and 20kHz...
..in which case for use as a vocal preamp you'd probably have to remove it, or put up with mud 'n' muffle!
Keith
