Brian Roth
The highest voltage anywhere in a 2254 will be 24 Volts from the power supply. The voltages in that section of the BA185 will be a tiny fraction of that.
Bri
Bri
Thanks Brian, I will get the ones you mentioned for the second kit I have.The highest voltage anywhere in a 2254 will be 24 Volts from the power supply. The voltages in that section of the BA185 will be a tiny fraction of that.
Bri
Thanks for your reply Scott. So I assume that you are saying there would be an advantage to using the 5uf over the 4.7uf. Is my assumption correct?if height/size is ok do you have enough leads on the axial to just mount them vertically? I've done it before with some heat shrink added to the leads
I'm not familiar with this project. I'm pretty sure 4.7uf caps were available when this project was realized .. Couldn't tell you why they wouldn't use them. Maybe someone familiar with this will have an answer. Seems like pretty tight tolerance....Thanks for your reply Scott. So I assume that you are saying there would be an advantage to using the 5uf over the 4.7uf. Is my assumption correct?
