Svart
So I've been doing a lot of thinking and realized something the other day that I seemed to have overlooked for some time for some reason..
I guess I could really start by asking, how does the signal path in your console route when you are just tracking?
I realized that the signal path of my console, even when all sections are switched out goes through a number of unneeded (op)amps when just tracking to the recorder. it goes something like this.
input, preamp(with servo), buffer(for low cut, high and low EQ), another buffer(for parametric eqs) buffer(for panning), summing amp for the main fader, balancing section/buffer to tape out elco. I have removed most caps in the channelstrips and replaced most opamps(that would cause DC problems) with FET varieties like the OPA2604 or OPA627.
whew, that's a lot of stuff to bypass. I would *like* to install a switch behind the preamp to route the signal straight through the balancing opamp to the recorder(tascam mx2424) using the preamp gain/trim for the adjustments. the mixdown would be the normal chain though. Anyone see a problem with this that I might not be seeing?
I thought about this since I ALWAYS switch out all eq and inserts and set the main faders to unity, pretty much just allowing the signal to move through without affecting it.
I have already installed switches in a pair of channels to bypass the internal preamp so that I could use outboard preamps like the 1272. I would like to try going straight to the recorder now and see how it works out but was just looking for some opinions.
thanks!
thanks!
