I was also going to say a thing or two about the old HP 8903 audio analyzer, I have one of them, you can find them on e-bay for around $500 USD, they are good solid units, I connected mine via GPIB to my computer and made a MATLAB program to control it with the PC, but you can also try and download Pete Millet's software for it which never worked for me which is why I ended up doing my own programs, you need a GPIB to USB interface which is not cheap.
You can measure Power, THD, SINAD, swept frequency response and SNR. The only downside I see with these units is that their distortion residual is not very low, -80dB if I recall correctly, thats equivalent to 0.01% THD, which is ok for many things but a bit high for testing today's ultra low distortion equipment, for tube gear it may be ok, if you have an external low distortion oscillator you can measure lower distortion single frequency figures but if you plan on using the 8903 oscillator, for instance to do sweep measurements the lowest you can get is 0.01% THD. You can try using something like Cordell's distortion magnifier but in the end I think a QA401 is cheaper and easier to use.
