Bowie
- Joined
- Jun 22, 2012
- Messages
- 369
A client of mine brought his vintage V76 preamp in for fresh tubes and though a couple were weak, there was something else causing a severe gain issue, only getting around 30db instead of 76. I traced it down to two bad grid resistors on the first and 3rd stage EF804 tubes. They are the 1M R59 and R73 on the schematic below. The resistors did not fry open, they were closed/no continuity. I replaced them and all is well but I'd like to know what might have caused this to happen.
Voltages all look good now. Client had this preamp "repaired" by a tech that the client feels screwed him over. The fact that one of the boards was not re-mounted correctly and lets the input transformer flop around tells me that the work was poorly done. Client says preamp worked for a couple hours before the gain dropped (must be when the grid resistors died). What should I be looking for to make sure this doesn't happen again?
![TAB_V76_80&120_schematic.gif](https://proxy.imagearchive.com/bbc/bbc608298c6de501a263ae8a1c02eb44.gif)
